retiredhfdExplorerJan 29, 2014Slide will slide out but not slide in?The bedroom slide will slide out just fine but won't slide in. This happened before and I replaced the switch. It worked about 3 times and now it is failing again. I have a 2003 Fleetwood Excursion wi...Show More
ScottGNomadJan 29, 2014If it keeps taking out switches then you may want to add a couple of relays so they carry the load instead of the switch.
Related ContentAdding power outlets in slide with no wiringarctic fox slide adjustmentEasy way to remove slide topper?slide out 120v harness issuesslide vs no slide
