wildmanbaker
Jan 29, 2014Explorer
Before you go to the trouble of re-wiring the slide, get access to the motor, under the bed. Check all the wires in the connectors to the motor. This happened to us once. After taking the bed base apart for access to the motor, I found a wire that was not seated in one half of the connector. After re-inserting the wire, and connecting the connection, everything worked as it should, and has been since the original problem. I originally started trouble-shooting from the slide switches to the motor, when I found the problem. It was also the bedroom slide.
