Bren53 wrote:
We did try with the engine running and still won't come in.
It's the right slide on passenger side. When you push the button you can here the motor but nothing happens. All other slides work fine. We did try pushing on slide while button was being pushed with no luck.
Is it total electric with a POWER GEAR unit perhaps? Does the motor have a lever (maybe enclosed in rubber) on the back to disengage the elect. brake. It could have been moved to the unlock position for manual operation inadvertently and especially if it's in a basement compartment.
