SCVJeff,
Yes they are hydraulic slides. Where bouts is the control board you are talking about? Is it the same board as shows the jack lights? If so ours shows no lights for the slides. Only buttons to push to retract or put slides out. Yes we found the procedure for doing it manually. We are really hoping we can find the cause and get it fixed. We will be on the go and stopping several times and will need for it to work. can you get to the solenoids from under the coach? Hubby couldn't see anything with going in under the steps.
Thanks for your help, I will post to the forum you gave.
Brenda
