You have the HWH system, and there is a manual retract process.
http://www.hwhcorp.com/mp349558.pdfHere is the complete list
http://www.hwhcorp.com/manretract3.htmlUnder the second step you will find the pump and solenoids. I think the passenger side front is the one closest to the door. On the end facing the rear there is a 1/4" release valve, open it about 2 and 1/2 turns and the room may start in on it's own. some times you can push it in by hand. If not follow the instructions in the above links.
After it's in be sure to close up the valve.
Good luck and let us know if you get it.
Dave
Go
