markop's avatar
markop
Slideout noise while underway
I recently acquired a new 2013 Winnebago/Itasca Sunova and am experiencing loud squeaking and rubbing noises from the driver side slideout while underway. The noise is directly behind the driver and seems to happen at all speeds. The slideout rubber gasket seems properly compressed with the slide in but not sure if it is an adjustment problem or something else. Thought I'd check the forum prior to asking the dealer to trouble shoot it.
  • I had the same issue on the drivers side slide on my 2013 Encounter 37TZ. Coachmen had my dealer work with the vendor on the issue, not sure who makes it, but the slide has cables. Turns out that the four brackets that attach to the outer part of the slide were mounted wrong. Once the bracket positions were redone...noises were gone.
