dougrainer
Sep 09, 2022Nomad
It is amazing the 97/98 Fleetwood Bounder owners manual has NOTHING about the Slide or Jack system. So, it will depend on the poster to supply more info. Brand and type Jack system. Brand and type Slide system. IF you have 2 separate Hydraulic pumps, only need slide system Brand. Both HWH and Powergear back then supplied 2 pumps. BUT, Dewalt also supplied a Slide HYD system. SO, without knowing what system you have, it is almost impossible to give to accurate help. The sound of a freewheeling pump, usually means that either the system is sucking air or the solenoids are not opening. BUT, sucking air would mean low fluid level and you should have seen evidence on the ground of a leak. Does your system have a key lock button interface inside for operation? Doug
38,782 PostsLatest Activity: Aug 31, 2026
