Yankee_Clipper
Sep 10, 2022Explorer
In my 97 Coachmen, the HWH hydraulic pump had an in-line fuse to each acivator component 4 levelers and hte full-wall slide. When this happened to me, it was a 5-amp fuse that failed from moisture. The pump itself cut off when the fluid got under 50% to keep the pump motor from burning up.
As noted above, there was a strap style chainfall to manually retract the slide.
I was under the forward booth seat and hooked to a mount under the cabinet under the counter where the trash compartment.
HTH,
HTH,
38,782 PostsLatest Activity: Aug 31, 2026
