dougrainer
Sep 10, 2022Nomad
Yankee Clipper wrote:
In my 97 Coachmen, the HWH hydraulic pump had an in-line fuse to each acivator component 4 levelers and hte full-wall slide. When this happened to me, it was a 5-amp fuse that failed from moisture. The pump itself cut off when the fluid got under 50% to keep the pump motor from burning up.
As noted above, there was a strap style chainfall to manually retract the slide.
I was under the forward booth seat and hooked to a mount under the cabinet under the counter where the trash compartment.
HTH,
There is NO pump cut off switch for fluid level or any parameter on HWH systems. Run the pump too long, it will burn up the motor. Doug
38,782 PostsLatest Activity: Aug 31, 2026
