donn0128
Sep 23, 2018Explorer II
williamp321 wrote:
Hydraulic. I have check fluide level and its ok.
You have a bad check valve. It is part of the solenoid, so changing the correct solenoid should cure the problem. BTW, do you have selector valves for your slide rooms? If so you might consider closing them after closing the slides and see if that fixes the issues before spending money
