map40
Jan 19, 2023Explorer
Reccomendations from the manufacturer will vary depending on several factors, but the most important is the structural integrity of the vehicle with the slides in vs the slides out.
Some RVs (mainly the ones with a lower cost) use the slide out closed as part of the structure. In these cases you need to level first and open the slide outs afterwards because the slides need to be part of the structure. The only issue is that when you open the slideouts the weight distribution will change and the RV might stress a little on one jack or even move if you are on soft ground.
The RVs in which the slideout wall is not part of the structure (a bus chassis for example) don't need the wall of the slideout to be in to maintain structure, so it is better to level the RV with the slides out to ensure great weight distribution.
I always believed that the safest bet is always to level first and open slideout afterwards, but me driving an Alfa, when the 4 feet slideout monster comes out you absolutelly can feel the RV change position...
