Sandia_Man
Feb 11, 2023Explorer II
Although our Monaco owner's manual states slides should be deployed first, I go by how out of level our coach is at the site we are currently in. If we are somewhat level I may deploy slides first, but more often than not, we level rig first. Once level our slides go out smoothly without drama from slide motors. When unlevel slides still move in and out fine, but our longer, heavier living/dining slide sure lets us know that being out of level is not ideal circumstances for drive motor.
On our rig slides can not be manipulated when engine is running, thereby they are normally deployed off house batteries which is an easy task with our 4 GC2 6 volt jars. Our power gear levelers however can be manipulated with or without motor running as long as auto park brake is set. Occasionally after we have leveled upon arrival, levelers may dig in and lose initial level after a couple of days. Again, with slides already deployed, we hear that the larger slides in main cabin don't appreciate the movement of the levelers while raising/lowering coach.
What does all that say, we do what we think is best for our rig depending on the scenario we are currently experiencing. Coming from an engineering/technical background, and working with various leading edge OEMS, you cannot simply duplicate every environment in which your equipment can be used. Also spent a few years writing both owners and service manuals, believe me not everything stated in a manual is rigorously tested for every imaginable scenario. I imagine RV engineers do their best, RV mfgs just to cheap to employ better designs.
