htowners
Apr 11, 2016Explorer
I'm sure you know this, but make sure your transmission is in park, parking brake is on, key in ignition and in running.
I had an issue with 1 slide and found it was the breaker on the control panel went bad, fortunately after contacting Tiffin, they pointed out the panel I had was for 4 slides, mine only has 3, so I was able to just swap to the empty breaker.
