- joloooteExplorerThanks
- RobertRyanExplorer
jolooote wrote:
How bout some engine info? Gasser? Diesel? Horse Pwr? Torque? MPGs?Chassis Iveco 50C18
Engine 4 cylinder turbo diesel
Displacement 2998cc
Power 130kw (176hp) @ 3200 - 3500rpm
Torque 400Nm @ 1250 - 3000rpm
Fuel Type Diesel
Fuel Capacity 100lt
Transmission 6 speed manual or automated manual
Gross Vehicle Mass 5200kg (downgradeable to 4495kg)(11,464lb)
Gross Combined Mass 8000kg(17,636lb)
Alternator Amps 140 amp
Chassis Voltage 12 volt
Wheel Size 406mm
Licence Requirement Light Rigid (Standard car licence for downgraded GVM).
Driver & Passenger Air Bags Not Available
Chassis Features
TBA
Privacy PolicyIveco AMT COWL ELWB 4350(AMT Automated Manual Transmission)
Exterior Length 7983mm (26ft 2 inches)
Exterior Width 2495mm(8ft 1inch)
Exterior Height 3150mm(10ft 3inches)
Wheel Base 4350mm(14ft 2 inches)
Interior Height 2015mm
Fresh Water Capacity 100ltr
Grey Water Capacity 100ltr
Black Water Capacity 19ltr
Hot Water Capacity 14ltr
LP Gas 2 x 4kg - RobertRyanExplorer
jolooote wrote:
The awning & door are on the WRONG side.
Nope right side, we are RHD in Auatralia. - joloooteExplorerTransmission?
- joloooteExplorerHow bout some engine info? Gasser? Diesel? Horse Pwr? Torque? MPGs?
- joloooteExplorerThe awning & door are on the WRONG side.
kaydeejay wrote:
gswcgi wrote:
Here we go again......!
I'd be very wary!!!! The steering wheel is on the wrong side. Need to get that fixed!
Take another look - it's on the "right" side :R
(Especially if you lived in one of the 73 countries that drives on the left side of the road)!
I get it was a tongue in cheek comment. Same Company is coming out with a much larger Class A, fairly soon I believe. - kaydeejayExplorer
(Especially if you lived in one of the 73 countries that drives on the left side of the road)! - RobertRyanExplorer
Your only young once!:B - gswcgiExplorerI'd be very wary!!!! The steering wheel is on the wrong side. Need to get that fixed!
38,769 PostsLatest Activity: Apr 04, 2026
