Gjac
Apr 30, 2022Explorer III
bobndot wrote:Rear axels can support 7275 lbs front 4630 lbs DW is 8290 lbs. That leaves 3615 lbs of fluids and stuff which sounds good to me. Seems a lot better than the MB chassis. It sounds like fuel economy is a wash also.
Gjac, I'm not sure how much weight the rear axle can support.
you would have to be careful loading-up that big 'easy to overpack' rear storage compartment.
Yes, I won't miss the jacks either Leveling at a campsite is real easy now. I installed a small set of bubble levels the cab of my 24' C. I have one screwed into the dash and the other over the passenger window. The bubbles tell me at a glance from the drivers seat. I can view N-S-E-W as I pull into a site or parking spot. Hardly ever use my levelers for leveling.
I only use my jacks to lift my rv when doing the tires. I lift it, then use jack-stands to the frame to support its weight.
