Gjac
Apr 30, 2022Explorer III
bobndot wrote:The GVWR is only 11,000 lbs. GVWR is 15,000 lbs. Their brochure says the CCC is 2490 lbs. It is a much lighter chassis than a 350. It looks like a unibody chassis rather than a frame type chassis that you would find on a 350.
Are you going by the advertised dry weight when calculating the payload ?
If so, a trip to a scale from the dealers lot would be in order before you load it up.
Most class C’s in this size will roll down the road, loaded for s trip in 12,000lbs range.
Incl : Fluids, gear , food, people , optional rv equipment.
