Gundog
Mar 17, 2019Explorer II
wa8yxm wrote:
WHat you are describing with that 'Flat phone like wire' is the battery temperature sensor. On a guess I'd say you have an inverter/charger not unlike the Xantrex Prosine. the flat 4(or 6) wire cable goes to a jack on it. IT is a Themp sensor.. Very little current flows in it and NONE to/from the battery.
Looks like it goes into the inside of the coach I do have a Xantrex charger after I inspected the wire it is broken in half about a foot from the connector. I am changing out the batteries because they were dry from over charging when I bought the coach last Oct. Do you think this cable being bad could have caused the over charging?
