Gundog
Mar 19, 2019Explorer II
shastagary wrote:
this is what the temp sensor should do.
Temperature Sensitive Charging When the supplied battery temperature sensor is connected to the unit and the batteries, the charge voltage is controlled based on battery temperature. The charger adjusts the charge voltage to the best level,minimizing water loss in wet cell batteries.Charge voltage regulation optimizes the bat-tery life cycle.
I have a new sensor ordered I called Xantrex I believe this is why the batteries were over charged. They told me to unplug the wire until I get the new sensor. The sensor is an option but with it plugged in and the wire being severed was probably the problem with over charging. It looks like who ever put in the last battery bank got that wire pinched in the hold down bracket.
38,780 PostsLatest Activity: Aug 05, 2026
