GGeorge wrote:
Would the anode rod also cause the water not to get 140 degrees? This water heater has an electric and gas system, both were on and the water temp seemed almost cold. The gas fired for 2-3 minutes the cycled off the light was on for the electric but that could be shot and I don't know that. I have a multimeter I just don't know how to use it, but I am learning.
Batteries are fully charged.
Will try the proxide. Thanks.
Make sure you have the water heater bypass valve in the correct position. Also do you have a full propane tank? You're having problems with two different propane appliances so maybe the tank is getting low on fuel or the lines got dirty? Just thinking out loud as I'm no expert on propane. Do the burners on your stove light up and burn good?
