Rhigley's avatar
Rhigley
Snow Chains
Any recommendation's on using snow chains on a class C motor home. Do they make an easy type to install and use. Will/can they cause damage.
  • Chains for outer dual is fine unless you are on an expedition then go double.
    Fit them on before you go. Leave 2 or 3 extra links if you cut to size.
    Lay the chain on a 2x4, drive up on the wood for easier install.
    Practice with no extra tools and using ski gloves in your front yard before you go.
    Use tensioners to keep them tight and prevent damage.
    Now you are an expert.
  • If you use them properly, they shouldn't cause damage.
    - Install them tight, get some good bunji cords or factory tightners to keep them tight and have a couple of spares. If the chains are operated loose they will hit things as the centrifugal force spins them outwards.
    - Don't run them for long distances on dry pavement. Besides wearing them out, the cross members will break and tear up anything within reach.
    - Don't run them for long distances on hard ice or dry pavement. The chains should sink into the snow covered pavement. I've seen tires where people ran the chains way too long on the chain cross members wore slots into the tires ruining them. Lazy driver with a lighter wallet.......
    - For easier installation, assuming you have rear duals, get two pieces of 2X4 or 2X6 about 8" long. These are to run the inside dual up on. This will lift the outside dual off of the ground sufficient distance to slide the chains under the tire and then provide room to work them around to get them tight.
    If you just need them for one trip, I have seen auto part stores in ski areas that sell chains and then if they're unused, they'll buy them back for about 50% of what you paid for them. That's steep, but if you're never going to need them again.......
    I've never used cable "chains" so I can't speak about them.
    Bill
  • You can buy cable chains. Easy on. They sell them for buses. I have them. I wouldn't be without them for my MH. You never know when you may need them.
  • Yes, they can cause damage.
    No, they have to meet the states requirement for chains. Odds you are over 10,000 so you need to check for truck chains.
    Best thing to wait out the weather. When big rigs go with out chains get in line with them!
    California chain requirements
    Note they are suppose to go over both tires, if possible.
