- Bendare2Explorer
travelbayshore14 wrote:
Just wondering if this is water damage??
Yes, that is water damage from the sink.
If the wood is still solid, it's an easy fix. A little sanding/ a little matching stain/ a few coats of polyurethane.
Polyurethane would be better around that sink, and it's easily brushed on.
Lacquer doesn't like water at all.
IMO that is a lot of water damage for 48000 miles...or a compulsive hand washer..?
(an old wood finisher).....aka....Ol'Ben - mike_brezExplorerHmmmmm such a great deal and it's still for sale today.:h
- Bill_SatelliteExplorer IISo, not dead in the water, just delayed......Odometers get changed out on a regular basis so doing so would never negate someone from passing any States emissions tests.
- rockhillmanorExplorer II
msmith1199 wrote:
rockhillmanor wrote:
randallb wrote:
A lot of the early 2000 digital odometers had issues where they would keep adding mileage when everything was shut off. This was a big problem with the Workhorse instrument clusters for about 5 years. I wonder if this instrument cluster is from the same vendor WH used.
I probably replaced 30 instrument clusters when BMW first made the move to the digital odometer with analog gauges.
Randy
When you replace it does it start at O?
Us folks with emission testing 'especially' Calif. THAT sure would not fly legally because the mileage is recorded at emission time to prevent tampering/fraud and you'd be dead in the water with your vehicle.
Why would you be dead in the water?
Friends of mine in California when for smog test and had all kinds of problems because one of the recorded repairs put the mileage in wrong. Didn't match what actual was at time of smog testing. They went months trying to straightened that out so they could get their plates. - Mike_HohnsteinExplorer III inspected a 95 BMC a month ago for a client, sides were definitely steel, caps are fiberglass. The example had 150k miles, original Cummins/3060, perfect inside with no squeeks or rattles, quick, sweet and silent running down the road.
I believe glass caps were employed after 89 or 90. If there was ever one built with laminated side walls, I'd love to see. - deandecExplorer
Mike Hohnstein wrote:
deandec wrote:
I looked at one many years ago. It was the fiberglass version of a Bluebird.
I remember it weighed about 23,000 lbs on the single rear axle.
That is @3,000 lbs overweight on most roads.
The axle was rated for 23,000 lbs so it was just a legal problem.
Could you expand on your comments? Trying to nail down what model you are talking about?
It was the BMC Mike Brez referenced.
I do not know if the 380 has the same configuration, but questions could resolve before paying the money. - Mike_HohnsteinExplorer II
Could you expand on your comments? Trying to nail down what model you are talking about? - deandecExplorerI looked at one many years ago. It was the fiberglass version of a Bluebird.
The axle was rated for 23,000 lbs so it was just a legal problem. - Mike_HohnsteinExplorer III have (now) a document from Cummins showing the true miles on a work order with work done in July this year.
They got the miles from the ECM.
The doc is a PDF file and dumb as i am about this electronic stuff i cant copy and paste it,i could send his email but theres no sense giving up his address and other info like CC number etc on an open forum.
Mileage was 61,582 in July of this year.
I had this coach for sale for more money,i think $110,000
and after no action for 2 months the owner asked me to dump it,hes old and has heath issues.
He has sold all of his Florida holdings and the coach is next.
From Randy's web site.
I've seen many op's come to the A forum asking about what's the best bang for your buck on a used DP. Here you go.........
__________________
38,778 PostsLatest Activity: Jun 10, 2026
