Eye75South
Jul 25, 2013Explorer
Soft/Crunchy spot next to Roof AC
2009 Coachmen 23'
Went back to the roof today and realized the rubber to the left of the AC unit was dislocated from the roof and the area (approximately 3.5' x 2') has a nice crunch when walking around on it.
There is no evidence of water entering the inside of the RV. I assume condensation from the A/C or rain is slowly trickling underneath the rubber and being absorbed by the wood/insulation.
I have a new gasket being overnighted and will remove the roof AC to inspect and replace gasket ASAP.
My primary question is what should I do about the soft spot. Can I let it air out for a few days and leave it or will it just get progressively worse?
I was thinking of taking a razor, cutting a large + sign over the soft area, replacing the damaged wood/insulation, glueing the rubber back down to the new wood and sealing up the cuts with eternabond tape.
We still haven't made our first trip, so any insight into my options would be much appreciated.
Thank you.
Thank you.
