I have a 1996 Tioga Montaro 28 on a Ford E350 chassis. I have Bilstein shocks and air bags. How do you tell if your springs are bad? Every time I go over an expansion joint or bump it sounds terrib...
Three things come to mind. First your Bilsteins will give you a harder ride than stock shocks. Secondly, you can adjust the pressure in your air bags. Third, try weighing your rig in it's "ready to go" load to determine the proper inflation pressure for the weight you are carrying and adjust appropriately. Steve
