I have a 1996 Tioga Montaro 28 on a Ford E350 chassis. I have Bilstein shocks and air bags. How do you tell if your springs are bad? Every time I go over an expansion joint or bump it sounds terrib...
When you say adjust the pressure in the air bags, do you mean higher or lower? I put them at 55 psi the last time we were out. I think it may be time to replace the air bags. They do not hold for very long. The tire pressure is 65 psi. Any recommendations?
