msturtz
May 17, 2015Explorer
You will need a battery isolating charge controller. You can't just connect them together. Each bank charges separately. Alternately, you can change your battery isolation relay to allow the converter to charge the chassis batteries. That way if shore power is connected both banks are charging and if the engine is running both banks are charging.
