garbonz
May 17, 2015Explorer
SunClipper wrote:
My '02 Winnebago Brave 32V is equipped with a small ( factory-installed ) solar panel connected to the coach battery bank.
I have been having problems with the chassis battery becoming discharged while parked with shore power connected.
Is there any reason I should not connect the solar panel feed to the chassis battery instead of the coach battery to maintain the chassis battery charge while parked?
thanks,
J.S.
No problem just do it. If you are just moving the panel wire from the chassis to the coach, it will work, depending on how much discharge you have.
However, the chassis battery should not be discharging very fast, so you may want to look into that.
