I'm intending to add solar to our rig when I get it figured out. Looking to do more than trickle charge my chassis battery. Looking to go off grid completely (and off generator too) for boondocking. A...
Have you calculated the voltage drop on 30 feet of #10 at 30 amps and 17 volts? It is 11% which would drop voltage to 15.13--a higher number than handy suggests.
That is 510 watts of panels--more than most folks need. For 20 amps (340 watts) the loss drops to 7.5% which works out to about 15.75 volts.
My own system is Mppt and line losses are less than 1%.
