Alex_and_Tee's avatar
Alex_and_Tee
Solar Panels
Our new motorhome has a 7.0 kw generator. I imagine to run all appliances A/C, refrigerator, tv's, lights, etc. it would take much less than 7.0 kw as not everything is on at the same time. We declined the solar panel option as I don't think 2 solar panels would run the A/C during a 115 degree AZ summer.
This leads to my question. We are thinking about buying a couple of acres in the Tucson area to use as a home base. We are going to build a covered, open sided car port with storage shed and concrete floor about 35' x 40'. It will be big enough to park our rig with slides out and room for patio furniture. It will likely be inaccessible to public power so we will have to install solar panels. How many kw should I plan to be able to generate? Should I just match the 7kw generator? Will also have to install a septic system so we don't have to dump tanks every few days and also install a water tank.
Thanks in advance for your insight!
