dsr27 wrote:
Doug
thanks for the reply. I had read that the Solera will drop one end when water builds up, so it's good to hear that it works!
Can you comment on the relative wind handling of the Dometic, Carefree, and Solera? I understand that none should be trusted to leave out in heavy winds, but it would be nice to know if one is really better than the others, or particularly, if the Solera is much worse than the others.
And since my only experience is with rigid-armed A&E awnings, should I consider the hinged-armed (and powered) units to be more, or less, tolerant of winds than rigid arms? I like the idea of powered very much, but might decide is not worth trying if it's known that these awnings can only be extended when it's dead calm.
thanks
Gary
NEVER trust an electric auto retract awning to do the job if required. The awning makers also do NOT warranty if the Auto retract fails to do the job in adverse weather conditions. The shed feature is nice, but usually heavy rain AND wind go together. Both contribute to a destroyed awning, in bad weather. I have had customers that the awning could not shed water fast enough with the auto shed arm features. I tell customers, ALWAYS retract when going to bed AND when leaving the RV to go somewhere. Doug
