mike brez wrote:
RLS7201 wrote:
Mike,
All the various front end combinations can be made to drive very well, including your P32. Buy the coach you like and if you don't like the way it drives, take it to one of the very knowledgeable RV front end places like Robert Henderson, Eric Davis or Precision frame and alignment. Those shop get it right. Correct alignment is not always by the book. There are "front end guys" and then there are "FRONT END GUYS".
Richard
I have done a lot to this front end. Henderson bell cranks,idler arm, inner and outer tie rods,drag link,Henderson front coil springs so no more air bags,Koni shocks front and rear,ipd large front sway bar with poly bushings.poly bushings on rear sway bar,Henderson rear trac bar,steer safe,Bielstien steering dampner,new inner and outer wheel bearings and seals,a few front end alignments with Henderson specs,new tires.
Having your front tires four feet on center I believe is the biggest problem. Also this chassis was never intended to be a motorhome chassis.
Sorry you was never able to make your P32 drive well. There are plenty out there that do. I've been responsible for a few that do drive well, so I know it's possible.
Richard
