time2roll
May 12, 2016Nomad
Get a battery charger for international voltage to charge your battery and then an inverter to run what is needed.
Mastervolt, Victron, Xantrex all make the equipment you need.
Or do without. This might be done with a locally bought 10+ amp battery charger to run the 12v stuff and propane. Maybe a couple solar panels (200 to 500 watts). You will not be running the air conditioner or microwave like this unless you have an on-board generator and you are allowed to run it.
If you could rent a motor/generator to convert power that might be feasible.
