Groover
Dec 07, 2020Explorer II
BurbMan wrote:
Current issue of RV Business is already showcasing some all-electric TTs. The addition of lithium batteries and solar make it workable. One mfr on the West coast is advertising "up to 2 weeks of boondocking or 2-3 nights of air conditioning" just from the inboard batteries and solar.
Some MHs have already gone all-electric with radiant in-floor hydronic heating and electric appliances...there's a already a genset on board so why do you need propane at all?dodge guy wrote:
The little eco boost will not last long at 100% duty cycle! Those little turbos will be glowing red.
That's what we all said when the eco-boost came out years ago, but that hasn't proven to be the case. Look at all the guys towing big TTs with F-150s with that motor, the duty cycle is no different there than it would be in a Class A.
The advantage to an eco-boost design is that it allows the F-150 to get better fuel economy when not towing the weight of the trailer. In the Class A, it's effectively never unloaded like taht.
I don't know if the eco-boost produces enough torque to get a 30,000 lb MH moving though...
My DP is 30,000GCWR and the Cummins is detuned to 300hp and 600lb-ft of torque. It is not a hot rod but gets the job done.
The Ecoboost produces two thirds as much torque as the Cummins so a 50% increase in the rear axle ratio would solve the problem nicely. And it gets about 20% better fuel economy than my V10 did pulling the same horse trailer. About 20% less than a 2019 Powerstroke I used for a while pulling the same equipment trailer. So the cost per mile was less than the Powerstroke with the fuel prices in this area. In comparisons I did using the same 12,000lb trailer the Ecoboost was much faster from 0 to 10 than the Powerstroke. I actually prefer towing the trailer around the county with the Ecoboost.
