Big_Katuna
May 11, 2014Explorer II
The advantages of in tank is that the fuel cools the pump and the fuel line is pressurized which helps prevent vapor lock. EFI requires 35-40 PSI and if you pull that much vacuum the boiling point will be very low. Add altitude to the mix and you will have problems. Best to replace the in tank.
Can you cut a hole in the floor? My tank was under the bed.
38,777 PostsLatest Activity: May 24, 2026
