DSDP Don wrote:
Elias....You have your numbers all wrong. Your front and rear gross axle ratings equal your gross vehicle rating. You have 12000 and 20000 equaling 31000, when it should be 32000. You then need to subtract your unloaded weight which is 26100. This gives you 5900 pounds of cargo capacity (fuel, water, people, food etc).
This is separate from your GCWR which is the coach weight and what the coach can tow, which is 10000 pounds.
So......you have 5900 pounds of cargo weight PLUS, 10000 pounds of towing capacity.
Thanks Don!
I knew I would screw up these numbers.
