DSDP Don wrote:
Elias....You have your numbers all wrong. Your front and rear gross axle ratings equal your gross vehicle rating. You have 12000 and 20000 equaling 31000, when it should be 32000. You then need to subtract your unloaded weight which is 26100. This gives you 5900 pounds of cargo capacity (fuel, water, people, food etc).
Since when did the sum of the axle ratings equal the GVWR?
I want to see someone load a vehicle that precisely!
Regardless, with a 33,000# GCWR and an empty weight of 26,100# the OP has a total of 6900# to share between what he loads in the coach and what he tows behind, provided the hitch rating is enough for the latter.
