fugawi
Nov 16, 2015Explorer II
Weight distribution needed? Help interpret CAT scale numbers
Can you please help me interpret these CAT scale numbers and whether weight distribution is needed here?
Is lifting 280 lbs off of a 4,780 lb front axle significant to handling?
The tow vehicle is a 2015 RAM 2500 4x4 diesel with factory rear air suspension.
The trailer is a 2016 Keystone Hideout 24RLSWE. It is partially loaded with gear (maybe another 250-300 lb will be added) and two propane tanks and battery. Overall length is 28’7”.
Here are scale results:
Truck Only
Truck Axle Front (CAT) 4,780 lb
Truck Axle Back (CAT) 2,960 lb
Truck Axle Total 7,740 lb
Trailer Axles (CAT)
Trailer Weight Calc
Grand Total (CAT) 7,740 lb
Tongue Weight Calc
Tongue Wgt/Trailer Wgt
Trailer with Water
Truck Axle Front (CAT) 4,500 lb
Truck Axle Back (CAT) 3,980 lb
Truck Axle Total 8,480 lb
Trailer Axles (CAT) 5,980 lb
Trailer Weight Calc 6,720 lb
Grand Total (CAT) 14,460 lb
Tongue Weight Calc 740 lb
Tongue Wgt/Trailer Wgt 11.0%
Trailer without Water
Truck Axle Back (CAT) 4,020 lb
Truck Axle Total 8,520 lb
Trailer Axles (CAT) 5,520 lb
Trailer Weight Calc 6,300 lb
Grand Total (CAT) 14,040 lb
Tongue Weight Calc 780 lb
Tongue Wgt/Trailer Wgt 12.4%
Thank you :)
Truck Only
Trailer Axles (CAT)
Trailer Weight Calc
Tongue Weight Calc
Trailer with Water
Thank you :)
JBarca 2007 Sub receiver label
buddy Marco's Duramax
MyReceiverLabel
