rgatijnet1
Nov 17, 2015Explorer III
You may want to thoroughly inspect the steel brake lines. The leaks that you have could very well be coming from rust holes in the steel brake lines. They are not that difficult, or expensive, to replace and it may be a good idea to replace all steel and flexible brake lines to insure that any other changes will work as designed.
In addition you may want to replace all vacuum lines in your vehicle to insure that you have the necessary vacuum to allow your system to operate.
38,766 PostsLatest Activity: Jan 10, 2026
