Late 90s and early 2k there were a few more DP chassis choices than today. For one, there was the Magnum chassis under the Safari, Beaver and Harney coaches. These were manufactured by SMC in Oregon and were mostly CAT 6 cyl/Allison 6 speed drive trains. I wondered when I bought my Sahara if I'd be able to get chassis parts, but so far I've had no issues. I do have a problem getting parts for appliances from manufacturers that are still in business though :(
Also consider the suspension on the chassis. Air bags provide a smooth ride but contain more parts that break. The Magnum chassis had a Torsilastic suspension called Velvet Ride that people tended to hate. I have the leaf spring/shock suspension and it's harder than air bags but doesn't bottom out, which the Velvet Ride can if not adjusted correctly.
Although CAT no longer sells engines to the over the road market, there are CAT service shops everywhere and the engines are pretty much bullet proof if you do the normal amount of yearly PM (fluids and filters). A call to CAT's hotline (877-777-3126) with the engine ID will get you all the service done on that engine over it's life.
