- RLS7201Explorer IIFleetwood has been heating the wet bays in their class A MH with the furnace(s) since 1986.
Richard - Fleetwood makes several different MH models, Pace arrow, Bounder and Southwind are some of the Class A products. All were built pretty much the same.
- Bill_SatelliteExplorer IIMost likely it's heated by the furnace.
- spud1957ExplorerPerhaps I need to be clearer.
I have not looked at it. As stated in the original post, I may go look at it. It's 3 hours away. The seller is unable to confirm right now. It does not have that detail in the brochure.
So, if anyone that OWNS a Southwind, maybe those owners could respond to my question. - If there were electric pads there should be a set of switches to activate them. Not likely or you would know.
- My Pace Arrow has heat ducts from furnace.
- spud1957Explorer
Old-Biscuit wrote:
Call Fleetwood with the VIN number and inquire --- 1-800-322-8216.
Check control panel(s) for Heat Pad On/Off Switch
Check wet bay a ofrea for ducted heat source
Yes I plan to do that if I go look at it.
S - Old-BiscuitExplorer IIICall Fleetwood with the VIN number and inquire --- 1-800-322-8216.
Check wet bay area for ducted heat source
38,782 PostsLatest Activity: Sep 10, 2026
