cmeade
Mar 14, 2016Explorer
Kayteg1 wrote:You should read 12804.9 of the CA vehicle code about an endorsement on your class C for 5vers with GVWR between 10k and 15k lbs and a noncommercial class A for GVWR over 15k lbs. (GVWR not actual weight).
I know that in CA and most of the 50 states RV are exempt from special DL requirements.
Meaning I can drive 15 tons or 25 tons bus, but when registered as and RV, no CDL is required.
There is much more to it as 45' require special DL, some states might require air brakes endorsement, but that is specific question you might ask with DOT division in your state.
Per my experience DMV employees are just trainees on the law and have no obligation to know specific.
