- wa8yxmExplorer IIIDepending on two things, the weight of the motor home and your home state, the answer is "Perhaps".
Some states require not a CDL but a special "Big Rig, Non Commercial" endorsement for RV drivers depending on the RV.
I think, and I stress the word THINK, Texas requires such an endorsement for RV's over 26,000 pounds. But not being a Texan and driving a 24,000 pounder, I have to stress THINK, check it out. - EffyExplorer II
wildtoad wrote:
A lot depends on your specific state and what size of class A. 26,000 lbs seems to be a break point between yes and no. If and what you tow, the combined lengths can also be a factor. Check with your states dmv.
X2 - check the laws in your state. usually weights, length - air brakes etc can come into play. It's not a CDL per se, it's a non commercial. Unfortunately a lot of MVA's have no clue on the exact classification or tests. Had a friend here in MD who have a DP where it's the 26k# limit and was trying to get theirs. Took a lot of research and diligence to even find out what the license was and how to test for it. So, I have to imagine if you didn't get it, most officers wouldn't even know to check. It might come into play for liability though and my friend said the class/test really does teach you a lot about your MH systems, like air brakes etc. - jplante4Explorer IIDo a search here on "special license". At least a day's worth of reading.
- wildtoadExplorer IIA lot depends on your specific state and what size of class A. 26,000 lbs seems to be a break point between yes and no. If and what you tow, the combined lengths can also be a factor. Check with your states dmv.
- 10forty2ExplorerNot typically, because it's for personal and not commercial use. I do believe some states require a special endorsement, but most don't.
38,773 PostsLatest Activity: Apr 23, 2026
