turbojimmy
Aug 24, 2014Explorer
rgatijnet1 wrote:
Depending on how often the coach was used, there could be some old gas and the crud is just starting to break loose. I would get at least two filters to have a replacement if the new filter plugs up also. You may need to flush the entire fuel system, including the tank, if the coach sat for a long time.
Mine sat for at least 6 years in a tow yard. Like a dope, I didn't change the fuel filter when I first put it on the road. It wasn't too long before it started to show signs of leaning out. Eventually it failed completely along the side of the road.
I replaced the in-line filter with a clear one so I could see what's going on. I also bought a spare. So far that replacement is holding up well with very little crud inside it. I've put a little over 700 miles on it so far without any issue.
To the OP - you may have an electric fuel pump installed on the right frame rail by the fuel fill. A lot of manufacturers did this to supplement the original mechanical pump. This is usually where you'll find an in-line filter as well. That's the one that was bad on mine.
38,769 PostsLatest Activity: Apr 03, 2026
