larry_cad's avatar
larry_cad
Explorer II
Feb 14, 2022
Splendede washer lint filter cleanout
Curious if anyone has come up with a good idea for cleaning the washer lint filter?
When we unscrew ours, we always get a flood of water onto the floor. The water runs out the filter hole, and down the front of the machine, to the floor.
We try to catch it with a towel, but a lot gets by us.
Wondering if there are any suggestions out there.
  • LouLawrence wrote:
    You first need to put the washer in the spin cycle and let it wind up. This will drain the water out and only a small amount of water will trickle out when you remove the filter. Remove the debris and wash it off and reinstall before the spin cycle is completed. Easy Peasy!
    Will have to try that. Thanks
  • It's not really a lint filter, it's more of a trap to catch and prevent larger things like coins from going through the pump.
    I used to check mine once a year but never found anything. When I checked it, I just had a bath towel ready, it was enough to catch most of the water.
    I tried a cookie sheet, but it just spread the water around more!
  • You first need to put the washer in the spin cycle and let it wind up. This will drain the water out and only a small amount of water will trickle out when you remove the filter. Remove the debris and wash it off and reinstall before the spin cycle is completed. Easy Peasy!
  • bgum wrote:
    How often do you clean it. Is it possible to blow out the line or install a pre-filter filter that is easily cleaned?
    Really don't care to try to remove the washer. It is in close quarters, and weighs a ton.
    I was looking for something I could do to the discharge end, as in the part just inside the little door that covers the filter.
    I can open the little door fine. Then I have to unscrew the filter and just at the very end of the threads, the water gushes out.
  • How often do you clean it. Is it possible to blow out the line or install a pre-filter filter that is easily cleaned?
