LouLawrence wrote:
You just make a slot above the location of the filter so you can reach down and remove it. I know it takes a bit more work, but it is done in some installations. It can also be a hinged door, but access can be provided.
Your comments made me go and look back at various install manuals for Splendide. OLDER models did have that removable lint screen like on some household models. But, the ones I have installed(AND OEM installs) did NOT come with a removable lint screen. Just the screw on adapter that you hook the flexable vent hose to. Also, nobody mentioned(I also forgot), the front debris/lint plastic filter, that you need to check a few times a month, maybe more if you use the washer/dryer combo a lot. This would not be on a dryer only. Doug
