tropical36
Jul 17, 2016Explorer
cbeierl wrote:
The dryer is electric (120V AC), but in the process of drying it takes in air from the coach and expels it via the exhaust vent, thus creating a negative pressure in the coach if there are no open windows or vents. The gas appliance(s) referred to are primarily the stove.
The water heater, fridge and combustion side of the gas furnace should be sealed from the coach and fed from/vented to the outside and so should not be affected by a negative pressure in the coach.
Good explanation, thanks and could see no way that this thing had a gas line running to it and especially with the way it can shake the whole coach with an imbalanced load in it.
38,763 PostsLatest Activity: Dec 05, 2025
