donn0128
Nov 07, 2018Explorer II
While you may be able to access stuff if your a contornist, its best to get a strong helper and pull it out. Once out taking it apart is easy.
There is a lint filter down low that you can access by removing the front panel. There is a gasket on the cap that might be your problem. More than likely you have either a bad or loose hose. Before anything, reach over the top find the valve assembly and try tightening the hoses.
38,782 PostsLatest Activity: Sep 20, 2026
