kdk
Oct 17, 2015Explorer
Cut the line to length you want with a razor blade. Slide a piece of shrink tubing over one end, butt the two ends together and slide the shrink tubing over the splice joint then shrink with a heat gun. If you want a very durable joint double up on the shrink tubing doing one layer first then slide a second longer piece over the first splice. Used this process many times with excellent results.
Blessings; kdk
Blessings; kdk
38,766 PostsLatest Activity: Jan 10, 2026
