overbrook wrote:
PhilR. wrote:
The problem is only a problem to those delivery companies. The drivers could not care less that their vans idle a bit higher. Especially since they aren't even in the van when the motor is at high idle in the first place.
To everyone else, it is a non-issue. Well, except to those whose lives are enriched by attempting to make it a problem....
A non issue? I don't think so. Check out the Sprinter forums - you'll see that a lot of Sprinter owners (non delivery drivers), are facing the infamous 'black death' caused by idling. You'll also see long discussions about rust issues, limp home mode, transmission woes, alternator problems, fuel injector problems and much more.
Anyone who owns or is thinking about buying a Sprinter should check out the forums at Sprinter Source. Find them at http://sprinter-source.com/forum/forumdisplay.php?s=0c59784135484e336e9cdba1fbaad310&f=3
I've owned two Sprinters - both were T1N's, and both had numerous problems. And yes, the owner's manual says to avoid extended idling.
Bill
Go to any forum and you'll see the same. I used to frequent the Ford Trucks forum when I was a Ford truck owner. You'd never buy a Ford if you used that as a baseline.
BTW, my manual says nothing about extended idling. I just don't do it and have no reason to.
