Community Alumni
Feb 17, 2018Not applicable
Sprinter Fuel Filler Opening
I just noticed something on our 2016 Sprinter that is different than the 2008 we had. The metal restrictor gizmo in the neck is gone. Previously, if you used a high volume diesel nozzle, you had to hold it in such a way that you don't spill fuel all over the place. Now I can shove that thing right down it's gullet. Did they remove that restrictor, or is it a missing item. Does not bother me, it all goes down fine with no backsplash. That is, unless you try to squeeze another few ounces in after the nozzle clicks off.
