missouri_dave's avatar
Aug 27, 2016
Sprinter motorhome boondocking
I find the sprinter based motorhomes kind of interesting. From what I've seen most have around 30 gallons fresh water and 30-35 gallons grey/black capacity. How long could a single person boondock with that kind of capacity before having to drain the tanks and fill back up with fresh?
  • Beloved Spouse and I (and the cat) tend toward the "glamping" side, that is, we cook real meals, wash real dishes, and take daily hot showers.
    We have about 40 USG of fresh water and that gets us a minimum of four days. So I would argue that you should budget about 5 USG per person per day. As our grey tank is under 15 USG, probably closer to 10, that is our limiting factor.
    With a composting toilet we have no black tank and a dump cycle of two to four weeks. (Cat box is generally good for a month with daily care. ;) )
    With big solar and big batteries we generally cook all electrically and usually cannot use all the energy we create unless we get a lot of rain or snow, in which case we simply idle the engine while cooking. We do not have a generator.
    Our heating system, hot water, and back up stove are all diesel, sipping from a 60 USG tank. Most folks with big propane tanks get one to three months, so that is not usually an issue.
    Fresh water in, grey water out, and waste tend to be the limiting factors.
  • That totally depends upon the person and his/her habits.
    I have 33 gallons of fresh water to use for washing and flushing, plus I supplement with drinking water from gallon jugs. 17 gallon black tank, about the same for gray. This setup can carry me easily for a week or 10 days without using any outside facilities. I use sponge baths or baby wipes rather than showering, although I do spend some water on washing my hair in the sink. I minimize water for kitchen use, have no pets, and have enough clothing to get me through that time period without washing.
    That said, water and waste are not my limiting factors. Electricity is. No generator, no solar - my choice and I'm sticking to it. LED lighting, minimal water pump use, a fan if it's hot, no television, very little furnace use. Those conserving measures usually leave me plenty of electricity for CPAP use and for charging my various electronics and phone if I stay up to 3 or 4 days in one place. Any longer, I need to drive so the truck alternator can charge the coach batteries (2 6V Lifeline AGM's).
    I hope this helps. Do try boondocking. Maybe start with 1-2 days and work up as you learn how it goes.
